how can i connect the korg kaoss pad kp3 to the denon dn-mc6000 mixer controller HELP
geposted Tue 21 Aug 12 @ 8:03 pm
I recall someone saying that there is a way to hook up an effect send/return through the mc6000, can't remember if it was possible though, check the user manual it will be in there... Otherwise you will only be able to effect the master out or use it as midi controller for vdj's internal effects, I posted the midi messages with a picture a couple of weeks ago, search the next line on google and you should find it.
site:virtualdj.com synthet1c kp3
geposted Wed 22 Aug 12 @ 2:10 am
The MC6000 doesn't have effect send/return, however you should be able to connect the master output of the MC6000 into the line input of the KP3 and then the line output of the KP3 to your PA system. This will allow it to apply effects to your master sound output.
geposted Wed 22 Aug 12 @ 4:23 am
It doesn't have send/return.........but it does have send!
Look at the booth section. It's labelled booth/send. There's a little switch that routes the individual channels to the booth outputs.
You could use that to send a signal to the KP3 inputs. The KP3 outputs would then have to be routed into one of the MC6000 input channels as a return, so probably channel 1 or 4 if you're using the MC6000 with VDJ.
geposted Wed 22 Aug 12 @ 5:31 am
