hi
Currently i have my gemini cntrl 2 setup on my desktop. But its not very practical, i would like to know if there is any way i can use my ipad as a monitor with virtual DJ 7 loaded on it and use my cntrl via usb into the ipad.
take this
with this
and this
makes something like this
would it work?
take this
with this
and this
would it work?
geposted Thu 23 Aug 12 @ 10:11 am
iPad can't be used as a monitor for live video display. The adaptor above is for transferring photos from a digital camera.
However, if you upgrade to the full VirtualDJ Pro then you could use your iPad as a remote control for VirtualDJ - Please see https://virtualdj.com/wiki/What%20is%20iRemote.html
You will still need to actually run VirtualDJ on a proper PC or Mac. VirtualDJ cannot currently be installed or run natively on an iPad, but this might be possible in a future version.
Another option is to use remote desktop software on your iPad to connect to your computer remotely and control VirtualDJ.
geposted Thu 23 Aug 12 @ 10:38 am
No problem I understand. Surely the controller might work though as its USB powered. I see guys are using the USB camera connector to use USB keyboards. I am keen to give it a try, I have som dj software on my iPad as well so will see if it does work. It will be great if you could include a fully functional virtual dj app for the iPad in future along with the use of midi controler
geposted Thu 23 Aug 12 @ 1:50 pm
Technically it should be possible if the device you are using is fully class compliant (No special drivers needed) and the DJ software app that you are using has been designed to work with it (Or has MIDI mapping capabilities.)
MIDI controllers that are designed/intended to work with iPad should come with a suitable cable, or a dock for iPhone/iPad.
You will probably find that most current DJ software apps for iPad only support a few selected controllers (If any.)
geposted Thu 23 Aug 12 @ 5:38 pm
