Well, i am not sure if i can tell excatly what my problem is, but i ll try to. Maybe later at home, i will be able to load some pics.
I have a setup of, Pioneer DDJ ERGO+Virtual dj pro+a brandnew HP laptop running W7. I store all my music in Itunes.
As you know, main folders are listed on left side of the screen of VDJ. In ddj ergo, you have browse button which you can travel through your songs in your playlist. And the song you want to choose is highlighted.
When you press shift+browse, you can travel through your main folders. My problem is, after sometime i started to play, when i want to go to main folders, the folders are not highlighted. So you can scroll down or up by browse button, but you dont understand at which folder (or playlist) you are at. If i click any folder by using laptop mouse pad, i gain back highlighting.
My first guess was about screen resolution. I tried different resolutions without any success. I use VDJ LE skin btw, which comes with ddj ergo. I didnt try changing skin yet. I ll give it a shot later. Anybody had the same issue in the past?
geposted Fri 24 Aug 12 @ 9:06 am
