this may seem like a pretty basic question, but when i set a cue point and start playing a track and then hit cue the track goes to the cue point and stops. i would like it to go to the cue point and play from there without me having to hit play. is there any way to do this? thanks.
geposted Sat 25 Aug 12 @ 1:27 pm
The hot cue bottoms on top do this. You can remap the cue button on the deck controls also.
geposted Sat 25 Aug 12 @ 2:44 pm
thanks - i figured it out pretty easily. i think the key was asking the question - as soon as you do that the answer comes right to you.
geposted Sat 25 Aug 12 @ 2:48 pm
Have you tried the CUP or Cue and Play script?.....try it out...it may be what you are looking for.....Just write down the old Cue script to save and try this one...U can always revert bk. to the default Cue action....
down ? pause & goto_cue : play type that into the Action box for the Cue button.....hope this helps.... =D
geposted Sat 25 Aug 12 @ 7:24 pm
