I have the freestyler plugin for virtualDJ to work my lighing off the laptop.
On freestyler there is a fav short cut key.. Is there anyway I can use the key in virtual DJ on a midi controller ?
So on my midi controller " MPX-10" I just a key and my fav tap on freestyler comes on & off ?
geposted Mon 27 Aug 12 @ 1:41 pm
Not in a position to check, but:
That should do it IIRC. You might need a 1 instead of the 255. Ensure you have VDJScript enabled in the FS plugin.
set '$fsvalue' 255 & set '$fscommand' 1
geposted Mon 27 Aug 12 @ 2:52 pm
just the man I was hoping to reply :)
geposted Tue 28 Aug 12 @ 4:54 pm
Amazing that worked with out changing anything :D ..
Ok then here is the next trick ..
Can i play a cuelist from pressing a button on vdj ??
Thanks
Top man & top work
Thanks
Top man & top work
geposted Tue 28 Aug 12 @ 5:22 pm
Same as above, but change the fscommand value from 1 to a number in the range 272 (toggle cuelist 1) through 287 (toggle cuelist 16).
You can change cuelist tabs with 266 through 271 (cuelist tabs 1 through 6).
These values are documented in the Sendmessage and TCPIP.pdf file in the Documentation folder of FreeStyler.
geposted Tue 28 Aug 12 @ 6:51 pm
ok then that great :D .. I will have a look now ..
geposted Wed 29 Aug 12 @ 10:54 am
Hay.
Thanks for helping with that but could you help me with a code for freestyler to make the hazer toggle to go to 3% and a other on so it goes back to 0%
Thanks
Thanks
geposted Sun 02 Dec 12 @ 8:29 am
