Hi guys
I'm new to the whole controller thing, so bare with me. But I've got at Numark OmniControl and i'm using VDJ Pro 7 (PC version). It all works just fine, there's just one small thing annoying me however.
Currently the LED of the SYNC button flashes with the beats of the song, but only if it's a loud beat. If there's a break in the song, the button stops flashing, and if there are other loud sounds in the song, it flashes on those as well. This is a bit annoying... I want it to constantly flash following the bpm.
So I thought maybe this could be sorted through mapping? Currently 'LED_SYNC' is not mapped at all, but if I map it to i.e. 'play', it lights up when the deck is playing. So this tells me that it should be doable. So after reading a lot about vdj script, i think the mapping should look like this:
'play ? blink (get bpm*1000/60)ms : off'
Is this correct? And will it follow the beat, or will it be off?
Hope you can help me with this.
Niels
Niels
geposted Thu 30 Aug 12 @ 3:04 am
I think you need to change the mapping to
get beatgrid ? on : off
If you want something to "blink" you can only currently use a time in milliseconds eg. "blink 1000ms" not the beatgrid (quantized). Requests have been made to include quantized measurements to all script timing actions but we will have to wait and see if it has been included in the next version.
geposted Thu 30 Aug 12 @ 3:20 am
Thanks, I'll try that when I get home :)
geposted Thu 30 Aug 12 @ 3:34 am
It didn't work :(
geposted Thu 30 Aug 12 @ 10:21 am
play ? get beatgrid
geposted Thu 30 Aug 12 @ 11:58 am
BTW: If you just use get beatgrid verb on your sync led then it will also stay on when the track is on beat but it doesn't play... I assume that you don't want it to stay constantly on when the track is paused/cued on a beat and that's why I gave you the above script...
geposted Thu 30 Aug 12 @ 12:00 pm
Mine Worked! I downloaded Virtual DJ 5.0.7 trial on my computer which already had Virtual DJ 7.4 on it. I was just switching skins< and walaaa!
I changed it from VDJ 5.0.7 to VDJ 7.4 and back to VDJ 5.0.7. If it doesn't work, just keep trying. You can use what i said above, but must understand it before downloading.......loooooool.
geposted Fri 08 Nov 13 @ 9:55 pm
I am using VDJ 7.4 for all this
geposted Fri 08 Nov 13 @ 9:58 pm
@kwesiquincy
Just wondering why you would come on here and literally say you stole something. Very interesting!!!
geposted Thu 14 Nov 13 @ 11:54 am
