How do I map my nano kontrol to use all the sample decks?
geposted Thu 30 Aug 12 @ 4:30 pm
check that page for all the scripting verbs (it's about 3/4 of the way down the page). Also note that you need VDJ Pro to be able to map controllers.
https://virtualdj.com/wiki/VDJscript_verbs.html
geposted Thu 30 Aug 12 @ 5:12 pm
Ok thank you have vdj pro forgOt o add that
geposted Thu 30 Aug 12 @ 5:45 pm
In that case please register your Pro serial number here: https://virtualdj.com/users/edit.html
Thank you
Keith
Thank you
Keith
geposted Thu 30 Aug 12 @ 6:12 pm
Ok thanks for all the advice I appreciate it.
geposted Thu 30 Aug 12 @ 6:45 pm
