hi everyone,
thanks to this forum i found to cause of my jumpy audio, the realtek gigabit ethernet controller, so id like you to help me out with my new issue broadcasting. what the best way for me to broadcast? heres my specs just in case you need them-
VMS4
custom pc 4.1ghz, 4gb ram
i have an old laptop at hand too if theres a program that will let me broadcast from the line in ?? but i really dont wanna use it unless i have too
thanks for you help in advance
kris
VMS4
kris
geposted Fri 31 Aug 12 @ 8:52 am
VirtualDJ broadcaster will allow you to broadcast using mouse / keyboard for $49, however if you want to use the VMS4 they you will require VirtualDJ Pro Full.
Keith
Keith
geposted Fri 31 Aug 12 @ 9:01 am
thanks for your reply, i have vdj pro i have been broadcasting but getting sound glitches all the time so ive disabled my Ethernet card so no internet connection :/ on this machine (if i dont it sound awfull ) so i need another way around this..................
geposted Fri 31 Aug 12 @ 9:15 am
Register your Pro serial number here: https://virtualdj.com/users/edit.html
And download the latest 7.05b version.
Regards
Keith
Regards
Keith
geposted Fri 31 Aug 12 @ 9:26 am
ok im really disappointed with this forum ive missed my set now :( im sorry i just didnt have time to scan through my emails for my s/n..............................................
geposted Fri 31 Aug 12 @ 11:00 am
It's not going to be an instant fix given the limited amount of information you have provided. Obviously a PC configuration issue so you should start here: https://virtualdj.com/wiki/Common%20PC%20Performance%20Issues.html
There's no magic bullet we could have provided to instantly solve your issues.
Keith
Keith
geposted Fri 31 Aug 12 @ 11:16 am
Your ethernet card is causing you trouble so you're disappointed with THIS forum for not helping you quickly enough? WOW, how bout you do some of the leg work yourself; did you try google? Did you contact the manufacturer of your ethernet card? There are some very sharp people on this forum but they are not here all day everyday waiting to help someone fix their broadcast issues as soon as the question is posted.
You are fully to blame for scheduling a set when you knew you had issues with your ability to broadcast.
geposted Fri 31 Aug 12 @ 1:24 pm
haha i feel like a fool for posting that, yesterday was a bad day and thanks for telling me strait il find my S/N and check back because im sure there must be away to use the laptop to broadcast from even if i install vdj on there and just run my vms4 booth to it ??
geposted Sat 01 Sep 12 @ 9:11 am
