What's up
I use a Hercules 4 set, with the Virtual DJ software that came with it -- Virtual DJ LE (DJ4SET)
I was just playing, doing my thing when I discovered that there was a problem when transitioning from my cue point.
I have a song in Deck A cued and ready for the transition. Deck B is currently playing the song.
When I press the play button on Deck A, you would assume that it plays from the cue point. Instead it starts from a beat or two behind the set cue point. I pressed play from the cue point after it was too late to transition, and it was working just fine -- it played from my desired cue point. It only seems like it plays from a beat behind whenever I want to transition. -_- It's really frustrating because this only happened from today, and I had to stop recording today's practice session because of it.
I hope this makes sense.
Thanks in advance
Thanks in advance
geposted Mon 03 Sep 12 @ 4:26 pm
You either have "smart_play", "smart_cue" or "beatlock" on... You can disable them withe the various locks on the skin or map the words in quotation marks to a button or key on your keyboard. Further instructions are also in the manual.
geposted Mon 03 Sep 12 @ 4:59 pm
