Topic: hi guyes
VirtualDJ can I use a microphone with it to do talk overs I would like make some demo's and send then to radio station's or if not how would I do this
Andrew
geposted Mon 03 Sep 12 @ 5:54 pm
What version do you have?
ok I have downloaded the free one do you haveto buy it to get the full version or what can I recored my DJ sets on the free version and can I connect my mixer to my computer
Andrew
Please see https://virtualdj.com/products/comparison.html
Home FREE is free limited software and has limited built-in recording facilities. It doesn't support using a microphone.
If by 'mixer' you mean a MIDI controller such as Hercules DJ Console, Numark MixTrack, etc. then you will need to purchase the full VirtualDJ Pro to be able to use these: https://virtualdj.com/buy/ (Some may come with VirtualDJ LE (Limited Edition) included that can be upgraded to the full Pro at a discount.)
If you mean a real hardware DJ mixer (E.g: Pioneer DJM series), then you will need to purchase VirtualDJ Basic or the full Pro to be able to output the decks separately to two channels.
If you just want to connect your master sound output from VirtualDJ into a single channel on a hardware mixer then this will work in Home FREE. You can record your mixer's sound output (Including its hardware mic channel(s)) using 3rd party recording software (E.g : Audacity) if it has a REC OUT of BOOTH output - See https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
Home FREE is for non-commercial use only. It cannot be used at gigs or for other purposes where you are being paid.
