I use a Hercules 4set with Virtual DJ LE (The one it came with).
I had a question about the cue function on my controller.
I would have a set cue point in my song, and everytime I go back to it (by hitting my cue button) the song pauses. I was wondering if I can somehow make it so, the song plays automatically when I press cue.
Sorry noob question. : (
Thanks in advance!
-david
Thanks in advance!
-david
geposted Thu 06 Sep 12 @ 12:21 pm
Your cue button is mapped by default as CUE_STOP which does the following:
If playing, pause and go to the last cue point. if paused, set the current position as cue point, and preview the cue as long as pressed.
There is also a CUE_PLAY which does this:
If playing, pause and go to the last cue point. if paused, set the current position as cue point, and preview the cue as long as pressed. if you kept pressed more than 2s (or the time specified), it will continue playing once you release. syntax: 'cue_play 1 1000ms'
But you can't change from the default CUE_STOP mapping permanently with the LE version.
Keith
Keith
geposted Thu 06 Sep 12 @ 12:28 pm
