Hi,
I just found a few MixVibes timecodevinyls in my vinly collection.
I would like to know if I can use them vith VDJ?
I also found a MV soundcard (something 44 or so. It is a USB stuff) Could I use that also?
THX
THX
geposted Sat 08 Sep 12 @ 5:10 am
with what version are u going to play them with?
geposted Sat 08 Sep 12 @ 5:23 am
I would like to test it with the latest Home Free version. (10 minutes only, but enough to make comparison with other DVS programs, or I can't do that? Only MIDI control is enabled for 10 min?)
geposted Sat 08 Sep 12 @ 5:28 am
If its a "Maya 44" then yes you can use that just go into the timecode setup. The Mixvibes vinyl is in the list of supported vinyl that you can select but I have never read of anyone using them, the reason I say this is because "torq" vinyl is also listed but that doesn't work so mixvibes may not.
full details of how to set up timecodes can be found in the Audio configuration manual
All the PDF Manuals
All the PDF Manuals
geposted Sat 08 Sep 12 @ 7:24 am
I'm having a problem when I spin my vinyl back to a cue point or just a couple of bars back. It jumps to the begging of the song.
What's the problem? Is it the sound card or the vinyl? Will other timecode vinyl such as Serato or Traktor work better than Virtual Vinyl?
I'm using Virtual Vinyl timecode w/ Numark CUE audio interface.
geposted Sat 20 Oct 12 @ 12:59 pm
Does anybody know if the "Serato performance series" will work on VDJ?
geposted Sun 25 Nov 12 @ 2:58 pm
It works. :)
geposted Mon 26 Nov 12 @ 12:48 am
