Dear all,
I have a new Numark N6 , the recordings mix has strange noise in the background,
the noise is like gas running inside the intestine.
Can anyone suggest what to config to mix please?
I suspect the problem is with sound driver, (I can't use ASIO, I'm just select N6 in the sound config menu).
This noise problem happened to me before with VDJ 3 + Hercules DJ Console classic.
I changed to X-ponent and worked great.
Now it happens again with the new N6, I want to use 4-channel N6.
Kindly assist.
Thanks in advance
Regards,
Richard Prado (Artimix)
Kindly assist.
Thanks in advance
Regards,
geposted Sat 08 Sep 12 @ 1:14 pm
Dear all,
I have just uploaded one of the mix that has the strange noise all over.
This is not an ad. :P
http://www.mixcloud.com/chillfader/underground-mixtape-063-angry-bird/
Kindly listen, especially at :
27:27 to 28:48
Many thanks in advance.
Best Regards,
Richard
27:27 to 28:48
Best Regards,
Richard
geposted Tue 11 Sep 12 @ 6:22 am
Why can't you use ASIO? That's what you should be using.
geposted Tue 11 Sep 12 @ 7:34 am
Hi, thanks for your reply,
I'm not able to use ASIO driver:
Current ASIO sound driver not working with message \\\"Error in the ASIO sound driver. Not enough channels.\\\"
OK for \\\"4.1 sound card\\\" with \\\"N4\\\"
I have some useful information from kind people here:
https://virtualdj.com/forums/167777/General_Discussion/Numark_N4_config_problem__kindly_assist.html?search=prado&page=1
Thanks again!
Regards,
Richard Prado
Thanks again!
Regards,
Richard Prado
geposted Tue 11 Sep 12 @ 12:35 pm
