Hi, I'm seriously baffled here, while doing a gig on friday a nightmare happened. My NS6 deck A pitch/tempo began to run real slow like I had set the pitch at -100%? it just happened after loading a video track about a half hour into the gig? I tried reloading the track same thing slow pitch? Tried another track, same thing slow pitch? Tried readjusting the pitch % adjustments slow pitch? Rebooted laptop & NS6, same thing slow pitch?? Swapped out laptop to backup laptop, same thing slow pitch on deck A only??? luckily I had my backup controller, swapped that & all was good.
I'm wondering if its a hardware issue=NS6 or a software issue?? This was the first time I had took the NS6 & my new Asus G71GX laptop to the club and I had to end up using my usual setup. I am running video with W7 32bit with 10gigs RAM , I believe W7 only sees 2.75gb RAM. I had thoroughly tested the NS6 letting it automix for 8hrs on a couple of occasions during the week with no problems. I was so frustrated I setup the NS6 & Asus when I got home & retested it again yesterday & the slow pitch issue vanished???? I am leary to bring the NS6 to the club now! Any suggestions or fixes would be greatly appreciated. Just for trouble shooting sake I reinstalled the NS6 drivers yesterday it seems to be workin fine now but I cant have it actin up live! Also now that I think about it the NS6 may have done this b4 on a couple of times but it quickly went away after i reloaded the track?
geposted Sun 09 Sep 12 @ 12:01 pm
Help please someone??
geposted Mon 10 Sep 12 @ 10:28 pm
I have had similar problems with my NS6, except I've experienced accelerated speed. To resolve this I usually hold down the + / - pitch bend button and it sorts the playing out. Could be worth giving it a shot?
I'm guessing something is going wrong between VDJ and the Midi signal from the NS6, and it's needing correction.
I hope that button solves your problem, if not it may be worth trying to replicate the problem so you can tell us what specifically causes the slow playback.
Si
Si
geposted Tue 11 Sep 12 @ 7:33 am
K, Thanx si1988uk I have to do a company Health Fair Today if it acts up I will try your fix & definetly let you know. Thanx again.
geposted Tue 11 Sep 12 @ 10:42 am
