Hello everybody,
I have a problem and couldn´t find anything using the search function!
After connecting an usb-Stick with my Macbook Pro while VDJ is running together with the VMS2, I cannot remove the stick without causing a crash! After the ejecting VDJ doesn´t work or react anymore! It doesn´t matter which usb-stick I use, the problem occurses everytime!
I hope you can help me!
Greetings Muhlo
Greetings Muhlo
geposted Mon 10 Sep 12 @ 4:07 am
VDJ is reading that USB there is some Info on it and try un-ck Show Volumes and Show Desktop before you run VDJ,that is why I just Keep my usb in the hub until the end of the night.
geposted Wed 12 Sep 12 @ 5:31 pm
