Would someone briefly explain to me the difference in PLAY vs. CUP?.....I've looked online and didnt see much. When is one preferable over the other? In what situations?....thanks
geposted Tue 11 Sep 12 @ 12:09 pm
Yes this seems to be a new phenomenon, have often wondered myself.
geposted Tue 11 Sep 12 @ 12:13 pm
There are various mappings available in VDJ for Cue & Play as below.
Cue_Stop
if playing, pause and go to the last cue point. if paused, set the current position as cue point, and preview the cue as long as pressed. you can specify a number ('cue_stop 1', 'cue_stop 57') to work with several cues. number 0 or no number works on the last used cue
Cue_Play
if playing, pause and go to the last cue point. if paused, set the current position as cue point, and preview the cue as long as pressed. if you kept pressed more than 2s (or the time specified), it will continue playing once you release. syntax: 'cue_play 1 1000ms'
Play_Pause
if paused, start the deck. if playing, pause the deck
play
start the deck.
Play_Stutter
if paused, start the deck. if playing, restart from last stutter point.
Keith
Cue_Stop
Cue_Play
Play_Pause
play
start the deck.
Play_Stutter
Keith
geposted Tue 11 Sep 12 @ 12:47 pm
Thanks Krad!.....
geposted Tue 11 Sep 12 @ 1:44 pm
CUP is explained here https://virtualdj.com/wiki/Cue%20And%20Play.html
geposted Tue 11 Sep 12 @ 1:58 pm
it just replicates the action of releasing vinyl..
geposted Tue 11 Sep 12 @ 11:48 pm
