Topic: Question's about virtual DJ
Question 1 I have virtual DJ love it but can you make the font size larger as I am Visualy impairment or can I have virtual DJ on full screen I have the free Version.
Question 2 What DJ controler do I need for virtual DJ
Thank You
Andrew
geposted Thu 13 Sep 12 @ 5:48 pm
1) Currently you would need to edit the skin to be able to do this - Please see https://virtualdj.com/wiki/font_size_change.html
If you purchase a version of VirtualDJ then you can choose from a wide variety of custom skins. Some of these have options built-in by the skin designer to change the font size.
2) This depends on your own personal preferences. A selection of popular hardware can be found on the hardware page: https://virtualdj.com/products/hardware.html
If you are just starting out, then an all-in-one controller with built-in sound card such as Hercules RMX2, 4-Mx, 4Set, RMX or MK4 would be recommended.
Please bear in mind that controllers cannot be used with Home FREE. You will either need to purchase a controller with VirtualDJ LE included or purchase the full VirtualDJ Professional to be able to use controllers and much, much more: https://virtualdj.com/buy/
These may help you also, although I made these over four years ago they should still be able to give you a good idea of what to do...
there's other video tutorials in my blog, a little dated but they will give you basic instructions on other vdj video plugins.
