Hello, I'm looking to try and set up a bounce-loop effect (creating a loop whilst the song continues to play behind it). I've realised I can do this with the 'Loop & Roll' plug-in, but I would like to have the effect mapped onto my keyboard with the various lengths.
For example, key 1=Bounce loop 4 beats, key 2=Bounce loop 2 beats
And so forth. I'm guessing this can be mapped but I am not sure exactly how it's done.
This is the effect-setting I want mapped to key 1 on my keyboard.
Alternatively, if there is another plug-in made specifically for the 'bounce-loop' that would work just as well!
I hope that all makes sense.
Thanks.
Thanks.
geposted Wed 19 Sep 12 @ 1:20 pm
some of the features are limited in the limited edition .....
https://virtualdj.com/products/comparison.html
you can get a considerable discount on the full pro as an LE user
geposted Wed 19 Sep 12 @ 1:47 pm
