My mac book pro has a new iTunes library full
Of top tunes. VDJ does not like my iTunes library. Any track that you load says 'error' in the deck window.
Tracks from my external hard drive play fine?
Does VDJ work with an iTunes library.... Any help please before my gig tomorrow night?
geposted Thu 20 Sep 12 @ 4:43 pm
Have you done "Add To DB" before you Recurse? I use a Toshiba and it reads and plays all of my iTunes library.
geposted Thu 20 Sep 12 @ 5:19 pm
Are any of the songs DRM protected (.m4p)?
If so, please see https://virtualdj.com/wiki/iTunes%20DRM.html
Also, which version of VirtualDJ are you using? Do you have the latest Apple Quicktime installed?
Also, see https://virtualdj.com/wiki/Error%20loading%20song.html
geposted Fri 21 Sep 12 @ 6:30 am
Yes I added to database and none of my tracks are protected... everything works swimmingly in Serato and am hoping for a similar result with VDJ
geposted Sat 22 Sep 12 @ 2:26 am
Find the folder in your C:\ D:\ E:\ drive, right click on each...., and "Add to db", it will import into VDJ, sometimes you might have to shut down and restart VDJ to take full effect of all the import covers and other fields...
Good Luck,
Joey..
Good Luck,
Joey..
geposted Sat 22 Sep 12 @ 12:00 pm
