i have problem.. i have behringer100 usb mixer.. it only uses the channel 1 of the mixer.. when i put track on the righ deck of vdj when i try to crossfade to the left its still playing instead to loose the sounds.. when i play to songs when i crossfade to the right their is no sound so basically the channel 2 of the mixer is not functioning to the deck 2.. is their any settings to change?
geposted Fri 21 Sep 12 @ 9:17 am
You said it yourself - the mixer only uses channel one for USB audio.
You will have to use the VDJ onscreen mixer, then the music (already mixed) will play through channel one of the mixer.
One solution would be to buy a sound card that has a minimum of two stereo outputs (4 channels) and connect the output pairs to separate line inputs on the mixer. In this case you would use "external mixer" mode.
geposted Fri 21 Sep 12 @ 10:07 am
