Hi guys,
Can someone tell me where in the xml file for '4 decks swap' skin I can change the colour of the song that's playing when the autoplay is engaged. At the moment it is white on aqua which is impossible to see.
Thanks
Thanks
geposted Sat 22 Sep 12 @ 9:22 am
You cant change that color. Its an internal color selection depending on the rest colors of the Browser. A Well known "bug" that will be fixed in next major upgrade.
geposted Sun 23 Sep 12 @ 7:04 am
Thanks for the info.
And as to the next upgrade. Still waiting........(yawn)!
geposted Mon 24 Sep 12 @ 10:00 am
But can't he change the color of the bar that shows you which song your on?? What skin are you using and I'll help you out.
geposted Mon 24 Sep 12 @ 11:05 am
