Hello.
I am using Virtual DJ Home Edition, and find it very entertaining. I am making a customized keyboard map so I can better enjoy mixing on the computer. I want to map a command that will affect the volumes, for example: 100% 75% 50% 25% 0%. I am having difficulty getting this to work. Is there a way to do this?
Thank you & Have a great weekend.
Rx Stylee
Rx Stylee
geposted Sat 22 Sep 12 @ 3:06 pm
Sorry, I just found VDJScript wiki and that has all the answers I need.
geposted Sat 22 Sep 12 @ 3:40 pm
you can save yourself a few keys if you change the volume/eq/crossfader by a set amount with a key eg
deck left volume +3.125%
deck left volume -3.125%
deck right eq_low +3.125%
deck right eq_low -3.125%
you should really set them at a relatively low percentage as when you hold a key it will repeattttttttttttttttttttttttt
the reason I used 3.125% is because it is in 32 steps & I think that is what the default skin is set at.
100 / 32 = 3.125
100 / 32 = 3.125
geposted Sat 22 Sep 12 @ 10:01 pm
Thanks for the help. The keyboard mapping is helping me get into the mix a lot more. I keep wanting to tweak it to get it exactly how I want it.
The way I see it, I have a controller at my fingertips with the keyboard: So many buttons!
Anyway, ... I am trying to get Deck A and Deck B set up on each side of the keyboard. I cannot seem to get this done right. VDJscript says to put Deck A in front of the command but it is not working. I've tried "Deck_A_'loop 1'" and all kinds of variations of that. Deck A Loop 1, Deck A 'loop 1'.
Can somebody tell me the correct forumula to put into the mapper ??
Thanks for your time, rock on good people
geposted Tue 02 Oct 12 @ 5:06 pm
deck 1 loop
to change the loop size you can use this and you will see the size change on the skin.
deck 1 loop_select -1
deck 1 loop_select +1
or if you want to specify the loop size "in beats" you do that after the word loop.
deck 1 loop 4
deck 1 loop 8
deck 1 loop 16
etc...
You are better off using "deck left" & "deck right" as opposed to "deck 1" & "deck 2" though, as then you can use more than two decks if you wish.
deck 1 loop 4
deck 1 loop 8
deck 1 loop 16
etc...
geposted Tue 02 Oct 12 @ 6:08 pm
synthetic...thank u man you have been very helpful. hopefully i will get this keyboard mapped to a way that promotes fluid mixing!
geposted Tue 02 Oct 12 @ 7:02 pm
you must have a rmx as i had to do the same thing.. you can also change the buttons to do multiple things.. it was posted by me in here before about the rmx 6 buttons having 12 features..
geposted Wed 03 Oct 12 @ 4:29 am
