I am trying to use deck 5 to use for microphone on my skin, how would I set deck 5 not be crossfader dependent (so it does not care where my crossfader is for the mic to go to the master output) ?. Thanks
geposted Mon 24 Sep 12 @ 2:01 pm
deck 5 cross_assign "thru"
geposted Mon 24 Sep 12 @ 2:54 pm
Interesting........ wonder if it has same effect on a deck that's rewired....... I'll let you know......
geposted Mon 24 Sep 12 @ 3:16 pm
Thanks djdad, is this better to use this in the xml file or to use it in mapper key that turn the mic on ?. Thanks again.
geposted Mon 24 Sep 12 @ 4:14 pm
You can add that script to the ONIT of your mapper or skin.
This way , each time you start the software, it will set the deck 5 to "thru"
geposted Mon 24 Sep 12 @ 5:09 pm
Thank you.
geposted Tue 25 Sep 12 @ 3:56 am
