i was wondering if any more experienced users could tell me a thing or two about scripting?
I have a 4 deck capable pioneer ddj ergo, and i wanted to do some 4 deck mashups, however it only has TWO volume sliders, even tho the 4 deck capability allows me to mash up 4 songs, its always impossible to get them the way i want, due to having to constantly change decks, lower volume, crossfade, rechange the other deck, volume, ect...
i currently remapped some buttons to try to do this easier (8 of them on the left side instead of samplers/hot cues are now deck 1-4 volume settings for 100% and 0%)
so i know its possible to at least do it faster than it was before, but what i REALLY want to do is make it so the volume slider is a crossfader between the 2 decks on each side of the normal crossfader
it would look kinda like this
Deck 1....................Deck 2
deck 3....................Deck 4
(it wouldnt let spaces be placeholders hence all the periods)
is there any kind of script capable of this? how complicated would it be?
i have a slight idea it would be something like this, but i am VERY new to scripting
VOLUME
crossfader ; deck1=100% ; Deck 2=0%
also i know i might need some kind of modifier to tell it each volume slider is a different crossfader, i read something about that on the vdj script help page
any help is MUCH appreciated, thanks in advance :)
VOLUME
geposted Wed 26 Sep 12 @ 12:09 am
Not entirely understood what u need to do, but this might help..
Map the VOLUME slider as ..
action_deck 1 ? deck 1 volume & param_invert & deck 3 volume : action_deck 3 ? deck 3 volume & param_invert & deck 1 volume : action_deck 2 ? deck 2 volume & param_invert & deck 4 volume : action_deck 4 ? deck 4 volume & param_invert & deck 2 volume
geposted Wed 26 Sep 12 @ 1:16 pm
I think this is what you're after....
crossfader
param_smaller 33.4% ? set '$vol_1_3' 1 : param_smaller 66.7% ? set '$vol_1_3' 0 & set '$vol_2_4' 0 : set '$vol_2_4' 0
volume sliders
device_side 'left' ? var '$vol_1_3' 1 ? deck 1 volume_slider : var '$vol_2_4' ? deck 2 volume_slider : deck left volume_slider : var '$vol_1_3' 1 ? deck 3 volume_slider : var '$vol_2_4' ? deck 4 volume_slider : deck right volume_slider
** note - this uses the command "volume_slider" so will not start working until you change the sliders position to match the position on screen. If you don's want this you can change "volume_slider" to "volume" (you can also use this script for the eq's and gain by replacing "volume_slider" with "eq_low", "eq_mid", "eq_high" & "gain_slider" respectively)
- if the crossfader is below one 'third' the volume sliders will control decks 1 & 3.
- if the crossfader is in the second 'third' the sliders will default to the left and right deck
- if the crossfader is in the last 'third' the volume sliders will control decks 2 & 4
crossfader
volume sliders
geposted Thu 27 Sep 12 @ 12:48 am
Thanks guys, ill try these out, thats probably as good as its gonna get
but i was saying like the volume slider itself is a crossfader BETWEEN the two decks on each side, and the normal crossfader is just the crossfader, so if i went to the left side with the REAL crossfader, i could use the volume slider to crossfade between decks 1 and 3, and when the real crossfader is on the right side, i would be able to crossfade between 2 and 4 with the volume sliders.
still gonna give these a shot tho.
thanks again :D
(to anyone who does know exactly how to do what i want tho help would still be appreciated)
thanks again :D
geposted Sun 30 Sep 12 @ 8:08 am
Just tried the first one and yep, he pretty much nailed it, SO MUCH THANKS
(also you guys should include this somehow as a mapping option for midi controllers with only 2 volume sliders but 4 deck capability)
geposted Sun 30 Sep 12 @ 8:17 am
Have Numark Mixdeck Express with Virtual Dj Pro. Is there any way i can map to be able to use cross fader..
geposted Sat 13 Oct 12 @ 2:38 pm
Simple answer is "No" and you don't need it mapped cause the mixer section is not MIDI. If your trying to record There's a guide in the wiki that'll show you how it's done......
geposted Sat 13 Oct 12 @ 2:47 pm
