can we make a panel inside a panel any example for it how does it work
geposted Wed 26 Sep 12 @ 9:20 am
Yes you can!
In order to create a panel inside another panel the only thing you have to do is to add the panel name in the panel definition:
<pannel id="MAIN1" group="PARENT" visible ="on">
<size width="35" height="35"/>
<pos x="100" y="100"/>
</pannel>
<pannel id="MAIN2" group="PARENT" visible ="off">
</pannel>
<pannel id="SUB1" group="CHILDOFMAIN1" pannel="MAIN1" visible ="on">
</pannel>
<pannel id="SUB2" group="CHILDOFMAIN1" pannel="MAIN1" visible ="off">
</pannel>
</pannel>
</pannel>
</pannel>
</pannel>
geposted Wed 26 Sep 12 @ 9:38 am
yo thanks bro i can play around for some time with this
i have a bug in my new skin what i've done this is the link to the image.
what might be the problem
http://s1153.photobucket.com/albums/p516/pradeep12789pb/
geposted Wed 26 Sep 12 @ 10:21 am
Can you explain your problem a little better ? I'm not able to pin-point your issue from the images you posted.
geposted Wed 26 Sep 12 @ 12:43 pm
at some point i can see sampler volume control on left corner, blue & red thick line shown in the image on both side.
that is where i've rhythm zone & song info with in pannels the pannel size is 211*70.
which is workin fine i don't no how to figure it out. & it is not mentioned in the skin script to happen.
this bug happen's when i load different skin & come back to my skin. & after loading the same skin for 3 to 4 times it becomes normal.
geposted Thu 27 Sep 12 @ 3:30 am
I assume you are referring to a vertical slider similar to the one you see in the Sampler Page, that appears on the top left corner of your screen.
This is a software bug, that is displayed if the browser is too small, and the sliders can not be displayed properly.
Not a big deal though, as its present in lot of skins with small browsers and skins with multiple browsers as well.
To get rid of that, you need either to have larger browser or smaller font.
geposted Thu 27 Sep 12 @ 9:45 am
yap that's right, as speaking multiple browser it's not gonna work right, if working
how do i do it & thanks for the advice
geposted Fri 28 Sep 12 @ 2:40 am
You CAN have multiple browsers on your skin, BUT ONLY ONE can be visible each time.
In other words you can use panels and multiple browsers in oreder to "resize/reposition" the browser...
geposted Fri 28 Sep 12 @ 4:25 am
Follow up question, when adding a sub pannel, could you explain the format for elements of the sub pannel ?. I trying to modify VDJ 4 deck skin to change the scratch pannel I dont use, to be a deck 5 for mic that is more important for me. need help with sub pannel elements. Thanks
geposted Fri 28 Sep 12 @ 7:57 am
<button pannel="SUB1" action="deck 5 play">
<pos x="500" y="100"/>
<size width="50" height="30"/>
<up x="+0" y="+0" />
<over x="+0" y="+2080+30"/>
<down x="+0" y="+2080+60"/>
<selected x="+0" y="+2080+90"/>
<overselected x="+0" y="+2080+120"/>
</button>
This example will put the button inside the SUB-PANEL "SUB1" of the previous example...
</button>
geposted Fri 28 Sep 12 @ 9:19 am
Thank you, when do you use the "group" script command ?.
geposted Fri 28 Sep 12 @ 2:10 pm
