I have W7 32 &64 BIT CDS.
Which bit shall I install 32 or 64 & say I install 64 on me macca can I install 32 on my pc?
geposted Wed 26 Sep 12 @ 9:13 pm
You will only have one licence so can't do both.
Depending on the RAM you have and supported hardware will determine whether it's better to go with 32 or 64bit. I personally would go 32bit as you still utilize 3gb RAM and it's more compatible with the majority of hardware.
Keith
Keith
geposted Thu 27 Sep 12 @ 12:33 am
i have 8 gig of RAM on my beast, its the last of the early 2012 b4 the new machines.
geposted Thu 27 Sep 12 @ 2:02 am
Well 64bit would take advantage of the RAM, however you will need to check any sound cards or controllers are compatible and have 64bit drivers for them.
Keith
Keith
geposted Thu 27 Sep 12 @ 2:05 am
fork it.... ill go with 32
geposted Thu 27 Sep 12 @ 9:32 am
