I just started w VD7, so maybe I am missing something...
But my HC4500 doesn't seem like it is doing anything. I select it on the mapping screen and when I (manually) load a track, the title shows up on the HC4500 and the Play button is blinking. However, none of the controls on the HC4500 actually do anything. I really don't get it.
HC4500 ASIO driver is selected in audio config.
Latest firmware is loaded. Windows 7.
Can someone please advise me on what I am doing wrong?
Or what is not set up correctly?
geposted Wed 26 Sep 12 @ 10:42 pm
First make sure that your HC4500 operates on "ALL" channels (Hold down MEMO button to enter the menu and on the MIDI Ch setting select "ALL"
Afterwards take a look here: https://virtualdj.com/wiki/DN-HC4500.html
geposted Thu 27 Sep 12 @ 12:47 am
That makes sense, however I don't get an option for "all" under MIDI Ch?
I get 1&2, 3&4 ,and 5&6. It was set to 1&2
geposted Thu 27 Sep 12 @ 7:52 am
I think I need to just run the firmware update procedure again.....something is obviously not right.
geposted Thu 27 Sep 12 @ 9:26 am
Re-updated firmware to current version.
I do not get the option to select "all" in Midi Ch, but it seems to be working now.
geposted Thu 27 Sep 12 @ 5:30 pm
Ooops! I was mistaken with my other DENON unit!
Nice to see you sorted it out though... :)
geposted Fri 28 Sep 12 @ 2:37 am
No worries. It is strange that it wasn't working though!
I'm sure I'll have some more questions soon :) I'll post a new thread based on the topic though.....
geposted Fri 28 Sep 12 @ 9:30 am
Not giving option for "all channels". It is not splitting my output to let and right side so I can assign to line 1 and line 2 on my Denon DX500. The same signal goes out to both. Even when I cue on other side the song comes out in my master output. I am running VDJ7 and wondering what I need to config right. I also have dual cd from Denon that the HC4500 is controlling. I saw that it said Version1006 on my hc4500.
geposted Thu 13 Dec 12 @ 4:06 pm
Windows or Mac?
Keith
Keith
geposted Thu 13 Dec 12 @ 4:10 pm
