I have hercules 4-mx. How do I set a mapping for when I press a button it automatically plays the beatgrid effect?
geposted Thu 27 Sep 12 @ 4:43 pm
effect 'beatgrid' active
geposted Thu 27 Sep 12 @ 5:47 pm
Thank you so much! I noticed it requires quotes to work, but others I see that are preset don't have quotes?
geposted Fri 28 Sep 12 @ 9:32 pm
The correct syntax to activate a specific effect is with quotes (single or double quotes, it doesn't really matter)
Other correct syntax are:
effect active which activates the "current"/"selected" effect and
effect X active where X is a number and it activates the effect selected in the X effect slot.
geposted Sat 29 Sep 12 @ 11:29 pm
