due to there being so many threads that turned out to be filled with complete nonsence about nothing in particular, i got bored reading them trying to find my answer, so hopefully a mod can answer me then lock this thread so we dont have another crazy thread.
ok heres my Q's
is there any plans to integrate the www.justeat.co.uk website and other similar sites depending on country/region instead of using a google search, to the get food feature? obv select the site depending on which language is used. could be too much trouble, but would be nice.
this could already be possible but not sure..... is it possible to have the ability to exchange audio setups as we do fx, samples etc?? so we can download and drop sound setup profiles into use without having to do things manually in sutiations where speed is needed and testing isnt really optional.
ok heres my Q's
geposted Sat 29 Sep 12 @ 3:53 am
For the second part:
It has been showcased that you will be able to save configuration presets and load them on the fly...
If you'll be able to "download" configuration presets, that I don't know...
For the first part:
Don't get me wrong and don't flame at me but this os a dj software! I always thought of "get food" as a funny "easter egg" on the software and not as a feature to be taken seriously...
Honestly on our era a smartphone (apple, android, windows phone etc) is more than enough for this job... And it would do it better!!!
For the first part:
geposted Sat 29 Sep 12 @ 1:32 pm
thank you for your answers, i dos see your point on the get food feature especially when justeat.co,uk has a dedicated app for both iphione and android, i just never thought about it till u mentioned it.
swapping out audio setups on the fly will be great, im glad its been showcased.
geposted Sun 30 Sep 12 @ 3:28 am
Asked and answered.
LOCKED
geposted Sun 30 Sep 12 @ 9:56 am
