New user here.My names is Jim.I own a nightclub and we have started using VDJ for our sound systems at the main stage and our VIP room.
I have djs that work the night shift,but not during the day.
To make things as simple as possible for the dayshift people I have created a playlist.I have the program set to autoload the list and to repeat.
I'm still learning the program and haven't figured out if there is a way to add songs to an existing playlist.
Any help is much appreciated.
geposted Sun 30 Sep 12 @ 9:12 pm
Just add New Tracls to the existing playlist in the AutoMix panel on the right and resave with the same name or under a different name if you want, you can reorder the playlist anyway you need it and resave as many times as you need...
Good Luck...
Good Luck...
geposted Sun 30 Sep 12 @ 10:20 pm
Thanks for the quick response.
That will do fine for me.
geposted Mon 01 Oct 12 @ 11:57 am
