I have just downloaded V-DJ & it is all good and fine, when i close the program will i have to download it again next time i want to use it, i have searched through the computer files for it but there is nothing, please help!
geposted Fri 05 Oct 12 @ 10:34 am
There is no icon on your desktop for the program?
Assuming you are using a PC (windows), Have you looked in Start/Programs/VirtualDj ???
geposted Sat 06 Oct 12 @ 2:53 am
yes, it's no-where to be found! I'm gonna try out some simular software. Real shame cause i really like V-DJ.
geposted Sat 06 Oct 12 @ 4:52 am
Maybe you do not have your downloads set to go to desktop.
If using windows 7, go to start and type "virtual dj".
If it was downloaded it will show up. Then you can right click on it.
You will then have an option to open folder location.
geposted Sat 06 Oct 12 @ 10:38 am
Search for virtualdj.exe
Make sure you are installing it with admin rights and also allow the installer to create a shortcut on the desktop if that's an option.
Keith
Keith
geposted Sat 06 Oct 12 @ 11:17 am
If you have downloaded a version from us you would have to install it before it would run.
It installs in a VirtualDJ folder in Program Files (the x86 one for 64bit) systems.
geposted Sat 06 Oct 12 @ 12:55 pm
