Hi...hope someone can help. I am running windows 7 64 bit with a Behringer x1622 usb mixer and VDJ7. I can broadcast music over shoutcast just finebut when using the mic I get inaudible static over the air at best. I had it working perfectly one time but VDJ7 crashed and I seem to have lost my settings in advanced configuration.
Please help...I have spent HOURS trying to configure this.
Thanks.
Thanks.
geposted Fri 05 Oct 12 @ 6:45 pm
VirtualDJ Home FREE doesn't support broadcasting, advanced sound configuration or using external hardware mixers.
Please register your serial number on the page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ then please support the software and its future development by purchasing it: https://virtualdj.com/products/comparison.html (Especially if you are working DJ and are making money as a result of using it.)
Make sure that you have the latest drivers/firmware installed for any hardware that you are using.
Also, see https://virtualdj.com/wiki/Recording%20your%20set%20or%20broadcasting%20when%20using%20an%20external%20DJ%20mixer.html
geposted Sat 06 Oct 12 @ 2:21 pm
I have purchased VIRTUALDJ7. Although I am working DJ I do an online show with ZERO compensation.
My mixer is a Behringer USB. Do I still need a line out from the board to the PC?
Thanks so much.
Thanks so much.
geposted Sun 07 Oct 12 @ 6:56 am
In that case, please register it to your profile https://virtualdj.com/users/edit.html and download the latest version.
Providing the USB sound card of the mixer supports multiple stereo channels (Please refer to the user manual) then you can use it with VirtualDJ Basic or the full Professional (Other versions don't support separate deck outputs to an external mixer): https://virtualdj.com/users/edit.html
If it only has a single stereo channel (This is often the case for mixers designed to allow basic playback and recording) then you would need to purchase and use a multi-channel sound card such as Numark DJIO. Or alternatively, use VirtualDJ's built-in on-screen software mixer and output your master output via the mixer's sound card. You can use your computer's built-in sound card for headphone pre-listen (Using the 2 cards sound card option.)
Please see our FAQ pages:
https://virtualdj.com/wiki/Pre-listening%20with%20headphones.html
https://virtualdj.com/wiki/External%20mixer%20pre-listening%20with%20headphones.html
geposted Mon 08 Oct 12 @ 7:56 am
