Hi, i recently bought a maschine mikro and my goal was to use it live with my other controller (a hercules mk4) which uses virtual dj LE but i can only get one program out of my speakers and not both, can anyone help me?
geposted Sun 07 Oct 12 @ 3:45 pm
I can't understand exactly what you want to do, but it's not easy to setup two different programs to use the same soundcard at the same time without conflicts, and it's almost impossible if you're using ASIO.
geposted Sun 07 Oct 12 @ 7:57 pm
i wanted to be able to mix my songs on VDJ and add in some different beats with my maschine while mixing both decks
geposted Sun 07 Oct 12 @ 9:04 pm
I have an MK4 and you can only have either control of mp3s thru vdj if you are inputting your maschine in either line 1 or 2 you leave only one line for vdj control
you may need an mixer and line the machine into one channel then output the MK4 to a seperate channel ... then mixer thru amp out to speakers its the only way I can figure you could use both
geposted Mon 08 Oct 12 @ 1:05 pm
