Just wanted to know how to download the skin for DDJ ERGO ? cant seem to find it on here and was wondering if any one could help me !
geposted Mon 08 Oct 12 @ 4:38 am
1. The skin for DDJ-ERGO is included ONLY in the LE version that comes with the controller. It doesn't exist as a separate download.
2. You have to be a registered user of the software in order to be able to download skins in general.
Thank you!
Thank you!
geposted Mon 08 Oct 12 @ 4:42 am
Thanks for that mate. I am a registered user but i didn't by the LE version of the ERGO it come with traktor. is there any other way to get the skin for VDJ ?
geposted Mon 08 Oct 12 @ 4:50 am
I'm afraid not! As I said, the skin doesn't even exists as a separate file available for download.
geposted Mon 08 Oct 12 @ 5:00 am
Unfortunately not. Some LE skins are released by the manufacturer for general download but I don't think that's the case with this Pioneer one.
Keith
Keith
geposted Mon 08 Oct 12 @ 5:02 am
You need to be a registered licensed user to be able to downloads skins and any other add-ons. Unfortunately the Pioneer DDJ-ERGO skin is not available separately. It is exclusive to VirtualDJ LE for Pioneer DDJ-ERGO only. The skin is not required to use the DDJ-ERGO. As a registered licensed user, you can use any skin of your own choice or you can use the built-in standard VirtualDJ default skin.
Also, if your DDJ-ERGO did not come with VirtualDJ LE, you will need to purchase the full VirtualDJ Professional to be able to use it with VirtualDJ: https://virtualdj.com/buy/ - If you like VirtualDJ, please support the software and its future development by purchasing it.
geposted Mon 08 Oct 12 @ 7:08 am
