Is it possible to male a shortcut key for clipbank?
geposted Fri 12 Oct 12 @ 1:00 am
Video_fx "clipbank" on
Enjoy
Enjoy
geposted Fri 12 Oct 12 @ 1:14 am
Mucho Thanks
geposted Fri 12 Oct 12 @ 1:27 am
uh oh it didn't work should I take out the quotations?
geposted Fri 12 Oct 12 @ 1:31 am
can you take it a step further and ask it to load sections of the clip banks?
geposted Fri 12 Oct 12 @ 2:05 am
Wouldn't that be nice
geposted Fri 12 Oct 12 @ 3:28 am
Opps, lol!!
video_fx_select "ClipBank" & video_fx
And to start different sections of the clip banks,
video_fx_button 1
video_fx_button 2
etc
etc
Enjoy
video_fx_button 1
video_fx_button 2
etc
etc
Enjoy
geposted Fri 12 Oct 12 @ 6:16 am
WOW
THANK YOU SO MUCH!!!!
geposted Fri 12 Oct 12 @ 3:42 pm
No problem, practice & enjoy!!
geposted Fri 12 Oct 12 @ 5:24 pm
Thanks for the script!!! I have a couple of additional questions.
1) What do I need to add to make the led toggle on and off? It's staying lit all the time now
2) Can I assign a know to scroll through the different clips? Tried but not sure if i'm approaching it correctly.
Thanks
Thanks
geposted Sat 13 Oct 12 @ 3:30 pm
geposted Sat 13 Oct 12 @ 4:02 pm
Sorry about the blank message. I got the button to toggle on and off. Another button was affecting it. Still want to know if I can get a knob (not know) to cycle through the clips.
geposted Sat 13 Oct 12 @ 6:04 pm
use the button 1 button 2 .........
choosing the clipbank also works exactly the same w/ multiple clipbanks
you just make it clipbank 2 clipbank 3 etc
i don't use jogs or a knob to scroll thru anything so i don't know if you can do that.....
to organize the 12 squares (buttons) i use the top row plus shift ....
in other words shift plus 1 , 2 .....9, 0, - (11), + (12).........
geposted Sat 13 Oct 12 @ 7:08 pm
Do I add the button 1, 2 etc to the other script? Do I use more than one button, or all on the same? Not sure I get it
geposted Sun 14 Oct 12 @ 2:34 pm
is it posible to do the same thing with soniques ? select them by name?
geposted Mon 15 Oct 12 @ 12:41 am
good question I can get the soniques to play with a hot key but I can't change them hopefully beatbreaker will see this
geposted Fri 19 Oct 12 @ 12:05 am
You'll need to disable the slide show and set up individual soniques in seperate folders/packets I would imagine, then apply a script to each one.
geposted Fri 19 Oct 12 @ 4:24 am
put the soniques in the buttons.....assign the buttons as shown above
geposted Fri 19 Oct 12 @ 8:59 am
I would think that it would be just as easy to set hotcues for VDJ Clipbanks 1-9.. But for some reason I'm having trouble setting it to work on either the Keyboard or the NS6 cues. Any help would be awesome, I was also thinking. There is a VDJ app for the IPad. I've got it, but doesn't seem to work because with my understanding you need an "Add-Hock" ? network with your PC and Ipad. I think it would be cool just to be abloe to have your clipbank boxes on your IPad right next to you, be able to go through different sets and tap at will. Thanks in advance.
Russell K.
Russell K.
geposted Fri 19 Oct 12 @ 5:02 pm
i will try to explain your questions tomorrow ....
you are over thinking it , it's easy .....
geposted Fri 19 Oct 12 @ 8:13 pm
