I have a Behringer DDM-4000 mixer.
I am currently using mixer input channels 1&2 with my Denon controllers with no problems.
I would like to configure mixer channels 3&4 to pass normal analog line input audio to the mixers output using the channel fader (slider).
I setup mixer channels 3&4 as midi channels, but audio will only pass straight from the input to the main output with no fader control.
For fader control, I have tried using “volume”, “gain”, “gain_slider, “volume_slider” for channels 3&4 with no luck (the “volume” command works fine with the Denon controllers).
Any idea’s on the code required to make analog channels 3&4 work with fader control?
Thanks in advance,
Clay
Thanks in advance,
Clay
geposted Fri 12 Oct 12 @ 7:30 pm
