Hi, all, and apologies if this is the wrong place for this, if so, please re-direct me.
I'm a PnC hobbyist DJ, mixing for pleasure, certainly not professionally.
Now, while Pro Basic. from standard install, uses the left and right cursor keys to adjust 'pitch_bend +/ - 5%' to nudge, can anyone please advise how to remap the up and down cursor keys to adjust the current 'deck 1/deck 2 pitch 0%' up and down by a tiny, incremental amount to permanently adjust the BPM (as opposed to having to keep nudging), instead of using them for scrolling up and down through the current folder? The mouse is good enough for that.
Sometimes, with just the touchpad for company, these tiny, precise adjustments just aren't possible, when a nimble button press would fix everything. Oh, the woes being a PnC DJ...
Thanks.
Thanks.
geposted Sat 13 Oct 12 @ 12:35 pm
my bad didnt read the post right this is only to adjust them when u press and hold the keys
go to key learn hit up,down,left or right
(i have left and right for deck 1 and up and down for deck 2)
input
_
deck 1 pitch_bend +5%
deck 1 pitch_bend -5%
deck 2 pitch_bend +5%
deck 2 pitch_bend -5%
input
_
geposted Sat 13 Oct 12 @ 2:43 pm
Thank you.
I tried what you have suggested, however, this seemed to just nudge, not stretch or reduce the distance between the peaks on the bar.
I'm looking for the keyboard equivalent of sliding the pitch slider to physically speed it up or slow down BPM to match.
Do I need to use set_bpm, or is that for something else?
Thanks again
Thanks again
geposted Sat 13 Oct 12 @ 3:36 pm
