Greetings. I have a question that I hope will be easy to answer for the vets here. I also hope this is the correct area of the forum to post such a question.
I'm using Virtual DJ Pro 7.1 with a Denon MC3000.
The controller has 4 buttons marked "EFX 1-4". Being a simple man, I used the "Mappers" area of Virtual DJ to assign a favorite effect to each of the four buttons. In the mapping section, the third EFX button looks like EFX3_BTN effect "overloop" active for instance (see image 1).
I used the third EFX button as an example because this is the effect I need help mapping. By default, it loads set to 4 Beats (see image 2). But to me it would be a lot more useful if it loaded set to 2 Beats.
Question, is there anything I can add to that EFX3_BTN command to have it load set to 2 Beats? Please offer any suggestions and I thank you all in advance for any support.
Peace
Peace
geposted Sat 13 Oct 12 @ 4:54 pm
on the button just map
effect 'overloop' active & effect 'overloop' button 2 1
it tells the second button to push in
geposted Sun 14 Oct 12 @ 7:45 pm
That did it. Thanks!
geposted Mon 15 Oct 12 @ 8:23 pm
