Hello, I just made my first mix: http://www.youtube.com/watch?v=V5czzgL4_uY&feature=plcp
I know he isn't perfect and that's why I would like that you give me some tips to be a real DJ
Thanks !
#TheSiQuR
Thanks !
#TheSiQuR
geposted Sun 14 Oct 12 @ 6:31 am
Tip #1, this belongs in the Music discussion thread...
MOVED FROM GENERAL FORUM
geposted Sun 14 Oct 12 @ 8:58 am
Pretty solid mix!
Firstly I would recommend recording and using songs with a higher bitrate (320 is best), it sounded a bit distorted to me.
The transition at 2:31 seems off by a few beats which is quite noticable
The cutting out of the bass for the first 8 bars of a new chorus/verse didn't really work for me, maybe try and do it for a much shorter time?
The transition at 4:11 wasn't beatmatched at all, I can hear what you were trying to go for but it needed to be in sync and maybe use an acapella?
The mashup at 5:00 is insane! I want it so bad!
The tranisition at 8:34 was a bit off, the song coming in (breakin a sweat) was two beats out, and you should have left the previous song playing for a bit longer or put the bass back on for the remainder of breakin a sweat. But that one will sound sick once you have perfected it!
But great work for a first mix!
geposted Mon 15 Oct 12 @ 3:32 am
