Hi,
I'd like to map the EFX4 knob on my MC3000 to move a loop. Right now the syntax I am using is
param_smaller 50% ? loop_move -10ms : loop_move +10ms
The problem with this is that if the knob is at any point left of center and you move the knob either direction (as long as stay left of center) the loop is shifted to the left (-10ms per movement). The inverse is true it the knob is right of center.
What I would prefer is if I move the knob counter-clockwise, it will shift the loop to the left. If I move the knob clockwise, it will shift the loop to the right, regardless is the knob is left or right of center.
I've searched the forums and haven't found how to do this. Any help would be greatly appreciated.
Thanks,
Eddie
Thanks,
Eddie
geposted Sun 14 Oct 12 @ 7:22 pm
your controller has been defined with a "zero" value so you need to map
param_smaller 0% ? loop_move -10ms : loop_move +10ms
then it should work ;-)
geposted Sun 14 Oct 12 @ 7:43 pm
Hi synthet1c,
Thanks for suggesting a fix. However, when I set param_smaller 0%, It makes it so that it only moves the loop to the right. It basically sets the center point to the end of counter-clockwise, about 7 o'clock. I also tried with param_smaller 100% and this set the center point to being at the end of clockwise, about 5 o'clock. When set this way, the loop only moved the loop left.
Eddie
Eddie
geposted Mon 15 Oct 12 @ 6:15 pm
I misread your post I think...
If you want to reverse the action just swap the + & -
param_smaller 50% ? loop_move +10ms : loop_move -10ms
geposted Mon 15 Oct 12 @ 8:26 pm
