Hi,
sorry I don't speak fluently English
I bought a Hercules 4-mx and I'm a full dj Pro Licence member
I'm playing with a Asus intel core I-7, 3610 Om, 2.3 Ghz, memory 8 Gb (K55V) and Windows7
I have a problem with the low frequencies which are too heavy... even with the level button of the low frequencie.
I try to find a solution on my problem but the only solution that members gives me is to download the "16-band equaliser" effect.
I donwload the effect.
I want to active this effect with Keyboard 'Shift+E' all the the time of my mix on all the decks
I change it in the mapping Key of keyboard 'Shift+E' but i don't find the right Action to use it on all the decks during all the time of my mix.
Can anybody help me ?
Thank you
and sorry for my english... :-)
Thank you
geposted Mon 15 Oct 12 @ 2:52 am
Your not the only one who thinks that but the VDJ TEAM has listened to the masses and when VDJ8 comes out you'll be able to change the frequencies.
Hang in there bro, the change you want is coming........
geposted Mon 15 Oct 12 @ 8:39 am
Oh, is that what he meant? The low frequency EQ....
I thought he was saying that the bass was too heavy on all his music.
geposted Mon 15 Oct 12 @ 10:54 am
Well I'm assuming that's what he meant, lol!!
geposted Mon 15 Oct 12 @ 10:57 am
try a VST EQ plug in
i just tried the macourteau plug in and it didn't work
it did used to work on xp .....
classic eq by kjaerhaus audio is good and there are others
geposted Mon 15 Oct 12 @ 1:39 pm
thx,
but it's effect plug-in and it must be active if you want to use it...
and by each new charging of track the effect becomes inactive...
doesn't exist an other solution to set the effect active during all the mix, or when you are charging a new track ?
geposted Tue 16 Oct 12 @ 10:39 am
you can disable "fx reset on load" in the options menu so the effects remain on when the track is changed ;-)
geposted Tue 16 Oct 12 @ 10:45 am
thanks, i try it tomorrow...
last question :
I have de effect " 13 band equalizer..."
but when I active this effect, it'sl only work to one of my decks...
Can you tell me how I can active this effect to 4 of my deck at the same time ?
last question :
geposted Tue 16 Oct 12 @ 12:56 pm
go into the mapper and include the mapping for it in "ONINIT"
it will be
effect "effect_name" active on
but you need to specify it for all the decks eg.
deck 1 effect "13 band equalizer" active on & deck 2 effect "13 band equalizer" active on & deck 3 effect "13 band equalizer" active on & deck 4 effect "13 band equalizer" active on
you may need to change the effect name if it is different to 13 band equalizer... I'm not really familiar with that effect to know it's name
it will be
geposted Wed 17 Oct 12 @ 8:02 pm
thx,
it's working....
have a nice day
it's working....
have a nice day
geposted Thu 18 Oct 12 @ 1:32 am
I use the 32-band equaliser but do you have any idea how to configure this equaliser to the best way... I mean to decease the bass and to increase the trebles...
And it's working but each deck takes his own effect.... and i cannot have only one effect '32-band equaliser' for all of my 4 decks...
I mean, i have to configure 4 effect '32-band equaliser' to each deck.... not so easy to get the same configuration on the 4 decks...
Any idea ?
Any idea ?
geposted Thu 18 Oct 12 @ 8:59 am
I think you should be looking into why all your music needs adjusting like this.
If you have purchased it online then it should sound correct without needing any equaliser.
If you have recorded it directly from CD it should also sound correct.
How are you listening to the music? Speakers? Headphones?
geposted Thu 18 Oct 12 @ 9:04 am
I purchased all my music online...
and i use speakers from Logitech 2.1 type Z-2300
With my RMX dj consol, there is no problem... the sound is good and not to heavy in the bass...
but with my 4-Mx the sound is not so good, to much bass....
geposted Thu 18 Oct 12 @ 9:11 am
Guys, watch out, OP might have an issue with speakers in his specific room. He might have some bass modes in annoying frequencies causing the bass to be overly heavy.
I would suggest OP to check if other software has the same effect - if yes, start moving speakers away from walls, etc...
geposted Thu 18 Oct 12 @ 9:19 am
no it's only with my 4-mx that i have this problem.... this morning, i mix with my RMX and there was no problem.... this afternoon I try same tracks with my 4-mx and the sound is bad... and i don't moved the speakers...
geposted Thu 18 Oct 12 @ 9:24 am
