Hi, I just purchased a Denon DN-MC6000 which doesn't come packaged with Virtual DJ in the UK. Is it possible I can get a copy of the software which is packaged in the US so I can demo the software before decided which software I want to upgrade to.
Cheers
Cheers
geposted Tue 16 Oct 12 @ 11:06 am
geposted Tue 16 Oct 12 @ 11:10 am
Denon market it with Traktor in the UK so you will need VirtualDJ pro full to be able to use the controller properly.
As above you can use the home free to test for 10 minutes at a time
Keith
Keith
geposted Tue 16 Oct 12 @ 11:20 am
Hi just did the same .but wen I down load the home version it doesn't seem to work properly wit denon 6000 ???
geposted Sun 25 Nov 12 @ 4:55 am
The home version will only allow you to run with a controller for 10 minutes at a time. You then have to stop and restart the program.
This allows you to try Virtual DJ with a controller before purchasing.
As for Virtual DJ not shipping with the MC-6000 in the UK, that was a Denon decision. Maybe if you raised the issue on the Denon forums they could provide you with a better explanation.
Cheers,
Roy
Cheers,
Roy
geposted Mon 26 Nov 12 @ 2:20 am
Please contact the support about this issue. Please ask for our European Operations Manager Heiko Jakovski.
With best wishes,
VirtualDJ Support Team
With best wishes,
geposted Mon 26 Nov 12 @ 2:49 am
