Hi all, I'm having a few video problems on VDJ. I am using a Macbook Pro & everytime I click on the video option & click the box to activate it produces an error message saying its having problems with the video drivers!?
Any ideas folks??
Thanks in advance
Mark
Any ideas folks??
Thanks in advance
Mark
geposted Tue 16 Oct 12 @ 3:33 pm
Try resetting to factory settings under the info tab, then restart VDJ.
Then under video, click on the drop down bar and select window, then activate.
geposted Thu 18 Oct 12 @ 2:25 pm
Resetting to factory setting will erase all the setting that you already have in VDJ. It is normal for any software to have such an ERROR without configuring your DISPLAY first in the display preferences. Go to Display Preferences then Click the Gather Window or the Detect Displays it will detect and gathered any possible setting that you have on your mac like your VDJ or if you have your TV connected to your macbook you will see that your TV has been detected.
geposted Thu 18 Oct 12 @ 4:35 pm
