Hey guys I have been trying to to figure out if you can use the VCI 400 to mix outside the software like the Denon MC6000?
in other words instead of mixing the audio streams with the virtual faders can you feed the audio to each channel on the hardware and mix it there? ( i tend to feel it sounds better mixed outside VDJ )
geposted Tue 16 Oct 12 @ 4:53 pm
so no one here owns the VCI 400 and can answer this ?
geposted Wed 17 Oct 12 @ 2:49 am
the vci400 is also a standalone two channel mixer on decks c/d, but you'd probably need another audio interface to route your main audio into the lineins on the back of the 400. maybe you could work something out in the advanced config, but i'm not sure you can internally route the signal to the lineins.
geposted Wed 17 Oct 12 @ 11:47 am
thank you for the input , I kinda figured this maybe the result but wasn't sure
geposted Wed 17 Oct 12 @ 7:11 pm
