Was curious as to how to do this. Im using a mixtrack pro and I dont use the pitch bend button during any of my mixing. I'd like to remap that button to skip forward and backwards 16 bars if at all possible. How would I go about doing this?
Thanks!!
Thanks!!
geposted Tue 16 Oct 12 @ 10:47 pm
goto -16 or goto +16
geposted Wed 17 Oct 12 @ 2:11 am
here is the thing. in the limited version its not posible. in the pro it is . in the pro you would click in the mapping then select the button you want to map then in the action you would write goto -16 or to skip 16 goto +16. you can map anything..
geposted Wed 17 Oct 12 @ 12:47 pm
ok thank you for the help!
geposted Wed 17 Oct 12 @ 1:23 pm
But wouldn't that be 16 beats? If so 16 bars would be + or - 64
geposted Wed 17 Oct 12 @ 1:29 pm
beats.. im sure i wrote this at 4 am with 30 in me.
geposted Tue 23 Oct 12 @ 12:48 am
