Hello,
I recently got a Numark Mixtrack Pro. As well as two Pyle speakers each respectively have 500 watts. I also bought an amp a Pyle PTA1000.
- When I hook up the speakers to my amp it plays for two-three minutes then the music won't play.
- If I hook it up to a Sony Home theater console the speakers play fine for a long time.
Should I get a new Amp or work with the Sony??
geposted Wed 17 Oct 12 @ 12:59 am
I say you go back to change that amp with warranty..
geposted Wed 17 Oct 12 @ 1:09 am
Alright thanks I bought a Technical Pro Amp instead I'll see how that goes.
geposted Wed 17 Oct 12 @ 2:45 am
amps are getting cheaper and lighter all the time. I just installed beringer amps that were so light that I though I had the empty demo.. it worked awesome.. I stacked 12 amps then ran them into a processor and then to a dbx unit .. the thing is you dont always get what you pay for... some times you get better some times you get junk.
geposted Wed 17 Oct 12 @ 1:05 pm
+1000
geposted Wed 17 Oct 12 @ 3:23 pm
I don't want to come off as snobby, but you are really buying BOTTOM quality amps, and that is probably your problem here. (lord knows I started with some pretty makeshift gear back in 1994!)
I'd wager you paid between $75-200 USD for your amp?...You can get used QSC/Peavey/EV/Crown etc at guitar center for that money bro!
check here: http://used.guitarcenter.com/usedGear/index.cfm
Same goes for speakers!
geposted Wed 17 Oct 12 @ 10:04 pm
Let's keep in mind, everyone, we all have budgets to work within, and not to pass judgement....
geposted Wed 17 Oct 12 @ 10:17 pm
