Following on from this discussion:
http://es.virtualdj.com/forums/167958/Wishes_and_new_features/split_cue__.html
Does anyone know how to map a button to enable and disable split cue? For example, I have the VCI400 and would like to map the load button on channel D to enable and disable split cue.
geposted Wed 17 Oct 12 @ 3:49 am
Because it's a sound configuration, I don't believe that can be changed on the fly. Plus, I wouldn't change a sound setting while playing, it will be noticed with an interruption when you change it. To do it on the fly, I would use a hardware mixer.
geposted Wed 17 Oct 12 @ 7:53 am
