So I just downloaded the new virtual dj 7.2 and my beatgrid effect is not working. Does anyone know why? Is this a bug or something?
Thanks,
A.M.
Thanks,
A.M.
geposted Sat 20 Oct 12 @ 12:08 am
Go in and adjust the grids, it was re-set.
geposted Sat 20 Oct 12 @ 1:09 am
A tip about it: do your beatgrid sets and goto virtualDJ > plugins > audioeffects and do a backup of "beatgrid.ini" file, then if you'll need to reinstall or upgrade the software, just replace the new file and your sets will keep the same. The odd thing is youll have to repalece new files everytime youll reinstall or upgrade VirtualDJ.
geposted Sat 20 Oct 12 @ 12:29 pm
Does anyone know where i can get a copy of the original beatgrid.ini file? I didn't realize it needed to be backed up before upgrading (never had that problem before v7.2)
I tried re-downloading from the FX section, but it appears that the original beatgrid effect is no longer available.
I was able to redo some of my beatgrid settings, but there are a couple from the original that I can't quite get right.
Thanks,
-Frd
Thanks,
-Frd
geposted Wed 21 Nov 12 @ 1:48 pm
https://virtualdj.com/forums/149138/VirtualDJ_Plugins/THESE_ARE_MY_FAVORITE_BEATGRID_PATTERNS____WHAT_ARE_YOURS_.html
The first one in the picture is the default one.
geposted Wed 21 Nov 12 @ 3:47 pm
Mines not working either ;-/
geposted Thu 22 Nov 12 @ 7:06 pm
I had to uninstall VDJ and re-install for it to work again, but that should do the trick for any one else having the problem.
geposted Fri 23 Nov 12 @ 6:31 am
