Hi
I recently installed VDJ Pro 7.0.5 now that it supports the Reloop Mixage, but the PFL doesn't to work work. I'm guessing that the mapping is for the standard model of the Mixage and not the Interface Edition that I am using.
Any advice on how to get it working greatly received.
Simon
Simon
geposted Sat 20 Oct 12 @ 4:28 pm
Please register your Pro serial number on your profile page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it.)
Both the CE and IE versions are supported (They are near identical with the exception of the built-in sound card.) If it's not working then your sound settings are probably incorrect. Please see https://virtualdj.com/wiki/DigitalJockey.html (The setup should be the same for Mixage.)
geposted Mon 22 Oct 12 @ 5:14 am
