Forum: Old versions
Topic: DENON S1200 ASSISTANCE NEEDED
Hey,
So I'm trying to run 2 Denon S1200's and A DJM350 with Virtual DJ Pro on a mac and after updating the hardrives it is finally reading them but now sound is only coming out of one channel. On the screen it shows the signals going through their respective channel (the screen shows both channels working) but from the decks to the mixer the sound is coming out of only channel 1 on the mixer. Both decks from virtual dj are playing out of the same channel on the mixer, thus making the mixer useless. no signal whatsoever through channel 2. When I used CD's it works fine and there no issue but only with virtual dj is it coming out of 1. How can I fix this? I really hope I can get this to work.
I've updated both decks and my config settings are input: none output: external mixer and the sound cards are both the s1200's.
Anybody have this issue?
geposted Sat 20 Oct 12 @ 8:05 pm
Please register your Pro serial number on your profile page https://virtualdj.com/users/edit.html and then download the latest version from the Download Center: https://virtualdj.com/download/updates.html
If you have not purchased VirtualDJ Pro then please support the software and its future development by purchasing it: https://virtualdj.com/buy/ (Especially if you are working DJ and are making money as a result of using it.)
Once you have done this, please see https://virtualdj.com/wiki/DN-S1200.html
